Kranberry
you know where i could get a tq3 rec?
What do you mean by plug the bec into the battery? What battery do i plug it into. How can i plug it into the battery if i dont need the red/black pig tail?
Ratterd wants to know if you soldier the pigtail to the ESC side of the battery pack and then plug it into the bat section of the RX will it cause any damage?
Click hereyou know where i could get a tq3 rec?
I think you meant to ask:John, Whats the difference between the 5955tg geared and the 5955tg robot servo's . apparently i bought a nomadio sensor last night. I hope that radio will work
Hi John looking at this combo for X-mas. MM with crawlmaster and your six cell pack. Would this be enough of would I have to go to the 8 cell? My charger can only handle 6 cells so I would also need a new charger. If you would could you recommend me one?
I have tried to hookup the cool BEC both ways you have described with no luck. If you could put up a diagram it would be most helpful. The speed contrler is a tekin reble 2 and the RX is a dynamite mini RX:-(
wich is better castle or cool beck. wil it make my servo stronger?
does axiom still make 35T motors? they aren't listed on their website, and that's what i am looking for for my scaler i am building
Got one for ya!
I just switched my pinion in my r2/goat from a 8t to a 12t. Wheel speed is crazy! Anyways, I noticed that when I'm going uphill and I let off the throttle, instead of it staying put it will slowly start rolling back, kinda like stuttering if that makes sense... Is this because the larger pinion or did I screw something up? Oh, and it is a brand new r2. Thanks!
i'm charging the 6 cell 2/3 saddle pack for the first time w/the hyperion charger i got from you...my question is... do i just have to enter the charge rate @ .01 and then enter ??? is it that easy ?? also at .01 charge rate how long should that take to fully charge ?? thanks JRH
thanks a ton JRH....i love this new hyperion charger....it's a lot easier then my super brain i had ....also ...how many times should i charge at this rate ??? what rate will i use after a few cycles??....thanks again
...and one more question ...on the hyperion's display window ,what is the number above the voltage ??
thanks for the response john....what rate should i charge at after break in ??I like to run about 5 charges at the .1 or .2 amp rate to break in the pack. The number above your voltage is the mah put into the pack.
