Maybe this should be in the KOH controller thread ;-)I have the KOH and brake light controller. I was wondering if I could still plug the esc wire into the controller if I have the power wire out because of the castle bec. If not then how can I wire it so I can still use my BEC?? Thanks!
I'm wiring in my LED light switch, I have the switch that has dimming.
The two pin plug that feed the (or will feed) the light bar; how can I tell which pin is negative and which pin is positive.
Both pons come out of the little black ball and there no polarity identification on either pin.
Thank you for the help.
This should really be in this thread:
http://www.rccrawler.com/forum/vend...ote-switch-leds-dim-function.html#post4286858
I'll help you here all the same.
There should be a white marker on the RCSWD. This indicates the positive pin.
It's actually kind of hard to see the one in this picture. Yours might have fallen off as it is only pushed over the pin.
Generally the positive pin is the one closest to the heat shrink (away from the center of the part). You could check with a volt meter to confirm, but you can just plug in your LED lights too. The LEDs will light with one polarity but not with the other. Reversing the polarity on an LED won't hurt it.
Hope that helps. Please send me a PM if I can be of further help.
Al
Heyok.
I have a 3PW and it's drifting, is there something I can do with it?
I've had them for about 2 years and they don't have much use. At this time only one is doing it.
Thanks Mike.
Just received 2 controllers, REALLY pleased with them! Great attitude and service with very quick delivery to sunny (!) Wales. Cheers Al.
First, I suggest leaving your receiver powered by six volts and that you consider doing this to feed power to your servo:I run 4s and my rx is set at 7.4. Which 3 position do I need to run a warn winch?
