Back when I worked in IT for my company we had a rash of lenovo laptop batteries that the latches failed on. Lenovo just sent us new batteries and told us to toss the ones we had. All that was wrong with them was the latch, the cells were fine. So I took home and figured I could find a use for them, if not in a truck then in a TX or even for a winch.
Starting to finally get around to see if they are of any use to me now, I have them tore down and I am trying to self educate on their specs.
I have:
6 Blue that I cannot find info on 18650 6H20313 60959 - roughly 2200mah
6 Panasonic green ST US18650GR - roughly 2000mah
6 Red that I cannot find info on HIUFJT5 - roughly 2600mah
AND
9 Panasonic grey NCR18650 MH12210 - roughly 2900mah
Obviously the 18650 is a industry ID and they are all Li-on. The capacity was easy to find for the ones I could ID, the others are a estimation based on the pack capacity. All colors are each from the same pack.
So the 9s will fit in a build I have as 3p3s, but I want to make sure I have enough discharge for this rig. The plan is to have a 4000 to 5000kv brushless system to make a all around Monster (The 55' for those familiar) . Previously it had a 15t brushed system and two 1600mah 3s 25-50c packs was enough to spread the load out and not over discharge a pack. I did nearly cook a single pack on my first test so I fully understand the issue here.
So what I need to understand now I guess is, how is the "C" rating figured? Is it a percentage of the total voltage? Is it per cell? What is the definition of the metric?
I have:
AND
