It's our pleasure to announce the newest packs we're carrying. I have these made to my specs and stocked in North Carolina. These are direct from the factory so they aren't marked up several times. Currently 4 sizes are available, but if there's enough request, I'll get other sizes.
These are also available wholesale to hobby shops and available in discounts for larger quantities.
5200 2s 30c - Trail Pack
5200 mAh / 2s / 30c - Trail Pack ($36 + shipping)
NickPower brings you the newest packs from Helios RC. These are the generation 2 batteries providing all the power you want and need.
This pack is designed for high run time and plenty of power. Use this in any SCX-10 trail rig. You can expect several hours of run time with this pack*.
Specs:
Typical capacity (mAh): 5200
Typical Voltage (V): 7.4
Dimensions(L*W*H mm): 139.8*47.8*25.5
Approx Weight (±15g): 308.0 (with wires) / 289 (without wires)
Continuous Discharge Current: 30C(156A)
Burst Discharge Current: 60C(312A)
Recommended Charge Rate: 2C
*Actual run time will vary based on rig setup.
This is a perfect pack for an SCX10 or Wraith with brushed setup.
6600 2s 60c - Power Pack
6600 mAh / 2s / 60c - Power Pack ($50 + shipping)
This pack is high voltage and high powered. This pack will run the most power hungry brushless setup!
Specs:
Typical capacity (mAh): 6600
Dimensions(L*W*H mm) : 138.6*46.8*25.2
Approx Weight (±15g): 300 (with wires) / 280 (without wires)
Continuous Discharge Current: 60C(396A)
Burst Discharge Current: 120C(792A)
These are the packs I run in my personal trucks. I do a lot of trail driving and will run pretty hard and basically get them down to storage voltage.
5000 3s 60c - Power Pack
5000 mAh / 3s / 60c - Power Pack ($52 + shipping)
This pack is high voltage and high powered. Use it for quad copters or any vehicle it will fit in. This pack will run the most power hungry brushless setup!
Specs:
Typical capacity (mAh): 5000
Typical Voltage (V): 11.1
Dimensions(L*W*H mm) : 138.2*47.3*36.8
Approx Weight (±15g): 367
Continuous Discharge Current: 60C(300A)
Burst Discharge Current: 120C(600A)
This pack will fit very nicely into a Wraith, SCX10, or Yeti. Running 3s will definitely give you the power to break stuff.
2200 2s 60c - Power Pack
2200 mAh / 3s / 60c - Power Pack ($30 + shipping)
This pack is compact and high powered. Use it for quad copters or any vehicle it will fit in. These are great in the Axial Yeti and other ultra 4 offroad racers including custom chassis and the famous Matzilla chassis.
Specs:
Typical capacity (mAh): 2200
Dimensions(L*W*H mm) : 108*33.8*26.5
Approx Weight (±15g): 194.0
Continuous Discharge Current: 60C(132A)
Burst Discharge Current: 120C(264A)
Helios RC
Specs:
Specs:
Specs:
Specs:
Helios RC
