awizner
If you want you can visit my channel on YouTube "scale wizz adventures" and see what I say.
:???:Hello,
I own a RR10 Bomber running a puller pro, ble pro, and SHV500 v2. I previously had the shv500 v1 but about a month ago it started to act up. It lost all its torque and would not turn to the right. I sent it in under warranty and Holmes sent me the SHV500 v2. Great customer serviceHowever after only running my truck once since then this new servo is now acting up. When I plug the battery in the servo begins to twitch and make odd noises. When attempting to turn the wheels the servo acts glitchy and makes a loud noise. It also doesn't have as much torque as it first did. It almost is acting like it needs a bec but it get direct power from the jst plug thats attached to the batter power wires on the esc ??? Does anyone know what it could be? I thought it might be a burnt receiver but I swapped that out and it changed nothing. Could it be the esc? I do not put my bomber through abnormal abuse, infact the last time I took it out I went pretty light on it. Any feed back would be great. This bomber has been a major head ache ever since I built it.
I wouldn't rule it out, do you have another you can use to test with?
Hows the wiring for the servo power could it be damaged?
As I understand it, those ratings are just to deter people who don't know what they're doing from exploding their motors. 4100kv is only 100kv over the 3s "limit" on the Rx8 gen 3. When it comes to things like this I would actually look at what the motor manufacturer says the max voltage/rpm is.Help me find an ESC...please!
I just nabbed a puller pro R, and all the ESCs that I own aren’t rated for 4100kv, so is it going to be a big deal to hook up my BLE, RX8 G2s, RX4, or RX8 G3 to this motor? The first 3 of these ESCs warranty’s have expired months ago.
I could order a MMX, but then I’d have to change the bullets on the motor, or is it common to make adapter wires for motors, like a 3” wires with 4mm bullets on the motor end, and 6.5mm bullets on the ESC end?
And finally how long before the...BEC-less Servo is back in stock. I can’t recall it’s name.
Yes, that servo is good up to 4s, which is 16.8v fully charged.
Run 4s with the 3500kv. If not, 2700kv and 4s will be a hair faster then 3500kv on 3s.
3500 * 12.6 = 44,100 rpm.
2700 * 16.8 = 45,360 rpm.
