MasteroFlego
If I absolutely have to, can I use a brushed motor with my Mamba X? (provided I can put the right connectors on the motor)
Sent from my Nexus 5 using Tapatalk
Yes you can do brushed on the mamba x.If I absolutely have to, can I use a brushed motor with my Mamba X? (provided I can put the right connectors on the motor)
What is the purpose of these capacitors on the stock 35 turn dynamite brushed motor in my vaterra ascender? I'm replacing it with a Holmes hobbies trailmaster sport 55turn and should I install these on the new motor? Still using stock vaterra ascender esc. Thanks!
Short answer: yes.
The X esc's don't have the refresh rate to catch the absolute peak, but that number is close...
It's a crawler, they draw almost no current.
C ratings are all made up anyway. :lmao:
I think he was referring to the HV500 servo. It was originally 2s compatible. I think the v2 is 3s compatible along with a stronger case and center pin.Directly cut & pasted from HH website (Bold are the differences, highlighted by me):
SHV500 V2
FEATURES:
Water-Resistant Alloy Case with O-Ring Seals
All Metal machined gears with improved pin strength
Upgraded Brushless Super motor with 200C rated magnets
24cm radio signal lead
24cm 12v power lead with female JST plug, includes male extension
2s through 4s Lipo compatible
1 Year Warranty
SPECIFICATIONS:
Weight: 73g
Dimensions: 41x20x40mm
Spline: 25 tooth (Futaba type) M3 threaded
Torque @ 11.1v: 32.4 kg/cm (450 oz/inch)
Speed @ 11.1v: 0.10 sec
Torque @ 14v: 37.5 kg/cm (520 oz/inch)
Speed @ 14v: 0.08 sec
_______________________________________
SHV500
FEATURES:
O-Ring Seals
All Metal Gears
Brushless Super High Voltage motor
Upgraded N38EH 200c rated magnets
24cm radio lead
24cm 12v power lead with female JST plug and 75mm male JST extension
3s Lipo compatible (16v max)
1 Year Warranty
SPECIFICATIONS:
Weight: 73g
I'm running a PP-2200kv in my SCX10.2 with 56/11 gear ratio. I ran it for about 45 minutes (mainly slow crawling) and the data log from my Mamba X shows that the maximum current draw was only 12amps. Is this a reasonable reading? If this figure is reliable, then I really don't need to buy high C rating lipo packs right?
Thank you.
I'm a little confused. Regarding the new HV500V2. In a post it was stated that it is capable of 2-3 S but the tech. spec. on the website only say 2 S compatible like the old version. What are now the correct specs.
Officially the HVs are 2s rated. Unofficially, the electronics will handle 3s just fine, but we don't have enough long term testing to say it is safe for long term reliability.
4s is no problem. Have a first gen shv and sticking to 16v for that reason?
When did the SHV500 v2 come out? It looks like I just paid $120 each for the 2 SHV500s I received 2 weeks ago. :-(
last weekish. The last batch of shv was also 4s safe. If you have any issues, you will get a v2 for warranty "thumbsup"
