JeremyH
Mmm...chicken...
Wow that great now! One of the prettiest trannys I've seen in a long time "thumbsup" Couldn't you lose quite a bit if you used some smaller wire on the motor? That stuff looks huge!
That could be taken waaaay out of context....... Sooo you've seen lots of pretty trannys?
Joking of course! :lmao:
Wow that looks great now! One of the prettiest trannys I've seen in a long time "thumbsup" Couldn't you lose quite a bit if you used some smaller wire on the motor? That stuff looks huge!
Its not as big as it looks. Its 20g & yeah...I could save some grams but again...I wasn't lookin for uber light on this rig.
The way I approached my 2.2p rig was this...I was going to build it with no target weight in mind. That didn't mean I wasn't going to take advantage of certain materials & parts to get her lightened up but I decided that if I end up with a 3.5lb car or a 5.5lb car...I wasn't gonna worry about it as long as she worked & she's workin killer right now @ 4lbs 3oz.
So I approached this build the same way. Im COMPLETELY tired of having to work on my rig the day before a comp because something broke, bent, cracked, stripped, fried or died so my MAIN objective was to have a RELIABLE RIG. Thats why I went with the C.I. outputs & Maxx shafts & yes...20 gauge wire running my motors. I know that 18g or even 16g will work but I feel much more comfy with a mid gauge wire running my power plant.
Make sense? Sure...I could shave a handful of ounces here & there but Im happy with her so far. If she doesn't work as well as I'd hoped at the end of the day...I might start shaving weight.
Easy man. Kids only 14 years old. I doubt he's seen ANY "trannys" which AINT a bad thing.
J.D.
How embaraskin Olive.
Huck, uk uk uk!
Anyways dude...yeah...its actually 16g wire if I rmbr correct. MAYBE 14g but doubtful. I'll check it in the morn.
Nice catch junior "thumbsup"
J.D.
Eve likes your pretty tranny JD. See what mind of negative influence you are having on the kid?
And JD doesn't need a super light truck. Britha straight does work with any truck. He was gonna run a Nikko at WCS but Del Monte said it would be unfair.
Ok. Most of that was a lie, but JD does work... On pretty tranny's...
...Ive never owned a foreign car in my life but always heard those Japanese rides go for 300k or better.
Should be. My FreeRunner has almost 260K on the ticker and has had no major work.....an alternator and a valve cover gasket replacement and that's about it. What happened?
Looking forward to seeing the footage of the rig........
There's your problem.....stop changing the oil so often!:ror:Oil was changed 2 weeks ago..
I missed this earlier.....I knew that you being an old man & all would catch that one. Good job gramps :mrgreen:
Seriously, I haven't changed the oil in my FreeRunner since last August....:shock:
Good luck with the repairs.
I missed this earlier.....![]()
I bet the drain plug and/or oil pan stripped. And probably just lost the plug and all it's oil whilst doing 80 which would show no puddles and initial signs that something was wrong. No matter the case. Situation sucks bas.
