BAD RC
Try contacting him personally. Reason they're not in stock. I believe he builds them to order.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
I have tried to calibrate esc's not sure if they are calibrated correctly or not but I have tried the servo test.and get the same result from servos as I do with the esc. So I connected 2 servos to channel 2 and 3 on my rx. Servo plugged into channel 2 goes forward and reverse servo on channel 3 barely moves at all forward and moves at the same rate as servo in channel 2 in reverse.to be honest I don't understand many of the new features on the gt3c or should I say what I'm doing to set them. And the instructions seen to be a bit incomplete and I don't understand then much either. But I followed a video and set up dig front and rear on channel 3 trim switch the mixing ratio on three fly to the dual rate switch and the dual rate reset on channel 3 switch.
[COLOR="Magenta"]Standard menu:[/COLOR]
- swapped behaviour of ENTER and END when editing items, ENTER now select
next value and END (+ ENTER-long) will end editing items
- Model number of channels and [COLOR="magenta"]Model reset[/COLOR]
[COLOR="magenta"]> choose menu NAME and press ENTER-long
> menu NAME will blink[/COLOR]
> choose "C" for number of model channels or [COLOR="magenta"]"r" for model reset
- reset will show NO/YES[/COLOR]
Ok so i r set the tx and re calibrated the esc the system seams to be working ok for now. I am still a little lost as to how some of the dig switch functions and dual mixing functions are and i am sure I will have some more questions but i now know enough to reset and start over if things get to out of whack. Right now im just looking to get it on the rocks one dig. I have 2 questions at this time one is a problem and one is dig question.
1) Both motors turn but they seem to turn at different speeds and start turning at different times. with forward throttle the front motor will start turning before the rear and at a slightly faster pace. with reverse throttle the rear motor starts spinnig first and at a much faster rate.
2) I set the dig function to the ch3 trim and have to push the button forward to have dig push down to turn off and back to have rear dig. I would like to have it set where I hold the switch in which ever direction I would like the dig function to work forward or rear and when i release it returns to 0 or both motors.
Thanks again
I am working on a video but having some trouble up loading right now but just wanted to update. I got most of the kinks worked out. I made one change to the dig switch and adjusted my esc's via castle link. Things worked well just needed to make some more adjustments on esc's. Turned everything off came back hours later made some changes on esc's then went to test. Now the front wheels and back wheels spun in opposite directions made some changes got them spinning in same direction but only one axle would work in forward and then only one in reverse and it was opposite axles. re calibrated esc same problems so I reset the tx and started fresh then calibrated the esc's about 4 times and have at least got both axles turning and in the same direction. But im back to them not being in sync again. Front will turn first in fwd, and the rear spins first in rev but faster. the rear will do complete rotations without the front ever turning. This occurs even when swapping channels for esc and rx. Not sure what is going on but i would lean toward the tx since both times i have reset it I get to a point where things are functioning well enough to drive.
The only setting I changed in the radio was the way the dig switch was working. And when I reset the radio then it starred working correctly again just the motors slightly off in start up and speed. The Holmes esc have adjustments to make to drag brake the Holmes hold and other options. I was setting the Holmes hold and drag brake so they were not as strong. I did each esc identical. The motors are timed identically. I don't know which end of the spectrum lies I'm just trying to figure it out. In one forum people say radio in the other it's the motors or esc. I'm just trying to figure it out not saying it's one or the other. The only thing I find odd is that when I reset the radio things started to work in a more normal fashion. And the only thing I had changed from the last time was the way the dig switch operated.
Your answer is three posts above>I just aqired a new GT3C rx with 6 channel tx's. I've noticed the webstore is closed. Will you be reopening soon??.
I'm in need of help with the most current and up todate info. Programming features and options. Also curious on how to water proof the recievers.
Thanks.
