It isn't that the Fusion is bad, it just isn't as good. But it may be more of a personal thing.
With my Revolvers and Tenkins there is more feedback and I know what is going on more so. The time between slow crawl and hitting it is different. When you are coming down a steep hill going slow and you are on and off the throttle super lightly it is different. The drag brake is just different for that moment. It just seems to allow a little more roll.
Going slow is great, a steady climb is great but when you are on an off the throttle it is different.
And it is big. It won't fit in to some builds as wheel. I have servo mounted on axles in a couple builds and it not fit in those.
I’ll have to make a bracket extension for the dig if I run the fusion, which I’m not going to do. I have to keep the motor facing to the rear because of that unfortunately. There is just enough room for the battery mount sideways right in front of the 3 gear though. For now I’m going to run the puller pro stubby, the micro x and the direct power HH servo on the axel. I do plan on a motor upgrade later. Any ideas for a deep offset wheel so I don’t rub my shocks and the chassis rails, And any insight on link placement to the chassis? I’ve been studying up but there’s so much information.
