Green slime in shocks?
-K-
Denmark
Hi guys.
I'm going to get some losi 4" shocks, but i heard that they tend to leek. I've also heard that you can stop the leeking with "green slime"..
And here is my question then; what is this "green slime" and where to get it?
I use it everytime I rebuild/disassemble a shock. very slippery & less chance if damaging the shock sealing o-rings. also makes them smoother.
You just coat the two rubber seals with it before you put them in the cartrage. I also put some on the shaft before sliding it through the cartrage.
It does not stop the shocks from leaking it prevents the seals from getting torn by the sharp edges on the shaft during assembly and then leaking later because of being torn.
