Government issued Micro
RC ESC 20a brushed car motor speed controller 1/16 1/18 brake off
In a smaller sentence (An EBay cheap ESC) Thanks DANALLY for recommending it
So after buying the wrong chassis I finally made head way. Had to cut the chassis down. I made the driveshafts
From help on here and got the body mounted...
What chassis should you have bought?
Nice truck and esc, should'nt really need brake with the worm gear setup in Losi?
yeah with the worm gear axles no need for drag brake. I used one of the esc's and loved it. They are super easy to water proof as well. I put some liquid eletrical tape on each end and with the clear shrink outter worked like a champ.
I should of got the 4.0" chassis I had to shorten this chassis with the 1/24 body and make new side plates to put it back together. I'll take some pics of what I ended up doing.
As you probably already knew the worm gear doesn't allow the car to roll from the wheel side.
You should make some links just to be careful. I had to make some because my driveshaft kept popping out. Ooh, that came out dirty.8)
I don't think I'll have that problem with mine I already did the driveshaft mod and lengthened them till the two ends almost touched just in case I had to adjust the chassis later for another body.
Ok been slacking on the pics here ya go still have to ain't the inside of bed and do the stripes on the side to match the big brother.
A d one more for of the grill
Ok time for the striping
Next is to paint the inside of the bed black to match the big truck
And make a camper shell for the bed as well
Since the windows are rolled half way down on big brother yota I went ahead and did the same for this one.
