After crawling with the Tarantula a couple of times I decided it need a better turning radius. When I built it I had to turn the endpoint down to keep the big tires from rubbing on the frame. I had 3mm hex extensions so I got some 6mm hex extensions. This allowed some more turing radius but at 100% the tires still rubbed on th frame real bad. Turned the endpoints down to around 83% and I think it will be ok. The turning radius sure seems better. I'll know for sure the next time I take it out.
Moved the 3mm hex extensions to the rear, it seems to handle pretty well with the front track a little wider than the rear
