GuyOverThere
Hello hello,
I "have" a pair of SCX24s (Ones in the mail still) and I was wondering what sort of aftermarket parts people are using in general and what there experience was with them?
For me personally my Deadbolt has some Mod19 parts from shapeways. I have the ultra low CG battery box that uses longer skinny packs and I like it. It went in smooth I prefer the battery style and its located nice and low. I also have the Low CG RX mount which brings it down a few mm. Then I put in a max servo and some new steering links.
I will say I like the low CG stuff both brought it down a bit and in particular that battery tray is pretty cool. Adding the max servo (or any upgraded servo) Is one of the better mods you can do for yourself especially if you add in a bunch of weight. I have brass knuckles and wheel weights from Hot Racing and the diff covers. trying to turn with the stock servo was basically a losing battle. Same deal with the stock steering link its rather bendy.
Now for my new C10 I'm not sure what route I want to take. I have some Rc4wd wheels and tires on the way. I'm seriously considering getting the inner fenders because I feel like it would give some extra mounting options for electrics. I also ordered up a couple of Barrage motors. I'm contemplating additional wheel weights and actually created another thread just to talk about shock options with you fine people.
Anyone have any suggested upgrades? I'm also interested in hearing what peoples experience is with after market links. Stock ones work fine but they are just so bendy not sure if its an area worth upgrading. On my new build should I roll brass knuckles/wheel weights or will the stamped steals from rc4wd be enough of an addition? I will almost certainly be running the diff covers still non rotating weight right at the axle is a tuff one to give up.
