c03morrison
Hey everyone! First time posting and it’s a question about the motor pinion gear in relation to adding a set of Traxxas Traxx to my Gen8 V2. I’ve checked out the thread which has a chart in shows everything about the gearing. Now I’ve been running stock gearing with a 3s when the chart says I should be at a 11 tooth gear. If I run with the Traxx on a stock gearing setup what’s the issue and will it decrease the life of the motor along with battery life? With adding a lower gear to like 14-15 help keep the motor cooler and not put as much stress on battery life too? Thank you in advance.
