Is this the motor you are running?
https://www.hobbywingdirect.com/products/ezm3650sl
If so, I believe those motors are 380 sized internals in a 540 can so they give up much in the way of torque.
From your gearing and electronic choice, it sounds like you use your Wraith for general bashing (jumping, mudding, etc) and not much crawling so there are tons of low cost sensorless motors out there that will fit your needs.
The easiest way would be change motors to something like this and change nothing else:
High-Efficiency GoolRC S3650 4300KV Brushless Motor for 1/10 RC Car O5T9 | eBay
It is a 4 pole motor with a larger rotor with the same KV rating as your current setup so by design it will output more power and run cooler at the expense of shorter run time.
The even better option is to move to 3S batteries with a lower KV motor (to keep the maximum motor RPMs reasonable) and gear down. This would give you more torque, more low speed control, less cogging at low speeds, better brake hold, and cooler electronics. A motor like this with a 3S battery geared at 84/18 would give you a little more top end speed in addition to all the benefits previously mentioned.
100% GoolRC S3650 3900KV Sensorless Brushless Motor for 1/10 RC Car M8R9 | eBay
