Starting my build with an Axial SCX10 frame, transmission and axles
Drive train:
- Robinson racing steel transmission gears
- MIP steel drive shafts
- Under drive gears out back and over drive up front
- Axial CVD's
- Beef tubes front and rear
- Vanquish products stage 1 kit UPDATE: Ditched the orange for black Axial aluminum hubs and knuckles
Suspension:
-RC4WD ultimate scale shocks drooped with no springs or oil (100mm) UPDATE: Gmade XD piggy backs (103mm)
-4 linked front and rear
-All ten links made out of 1/4" brake line, 8/32 threaded rod and Traxxas Revo large link ends
-12.50" wheel base. The front is thrown way out for a better approach angle
Wheels:
-1.9 Proline Interco TSL SX super swamper tires
-Crawler Innovations two stage foams, medium in the rear and soft in the front
-Motoworx Limited Edition 10 hole aluminum rims and center caps
Body:
-Tamiya Hilux (Toyota)
-Curby customs doved the cab, shortened the grill, made a new hood lip, cab back, shaved the bottom edge off all the way around and filled in all the other unnecessary holes through out
-Tinted windows so I don't have to do an interior (yet) UPDATE: Tamiya interior and driver with no windows
-Going to be caged with 3/16 brake line, silver soldier brazed. Hinge-able for battery and maintenance access
Electronics:
-Temporary Axial 55T motor UPDATE: brushed Tekin Heavy Duty 35T
-Temporary Gens Ace 2 cell 5000 25c battery UPDATE: Onyx 3 cell 5000 25c
-Castle side winder SV2 ESC tuned via Castlelink
-Savox SC-1267-SG servo
-Castle 10 amp BEC @ 7.4v
I already mirrored the transmission to reduce torque twist. Running Beef tubes front and rear instead of having rotating weight in the wheels to ease up on the drive train
Drive train:
- Axial CVD's
Suspension:
Wheels:
Body:
Electronics:
