Ambis
The old thread about the "bad" one-piece Xtra Speed gears is here. I thought these deserve their own topic, since these are far from the world of horribad that those one-pieces are.
This thread is about
Xtra Speed Steel #45 Helical Spiral Gear & Pinion Gear Set 30T / 8T For Axial SCX10 II #XS-SCX230075.
Ok so I haven't driven these yet, that I will do tomorrow after work.
But my god how great these feel! "thumbsup" 20$ (per axle) for a set of gears that look and feel exactly like the proper Axial AR44 gears (which will probably be somewhere around 35$?). These ones are definitely machined, not cast.
I took a video of how these spin:
https://www.youtube.com/watch?v=iCfU8XqeA98&feature=youtu.be
(NOTE: The driveshafts are not attached to the t-case )
It was impossible to have the one-piece gears run this smooth. I tried to shim the old ones every which way, but still they would roll in one direction fine, but with the other direction they would bind really bad.
With these, I just put maybe 0,4mm worth of shim opposite to the ring gear and nothing for the pinion, other than completely prevent it from moving inside/outside. And they are almost like butter smooth.
The set weights in at about 22 grams, and with a vanquish steel locker, around 36 grams (without screws).
I am really looking forward to seeing how these hold up after some 10 hours of runtime. (This rig weights in at about 4,5 kg with battery.)
I have really high hopes for these to function and last like the Axial ones do. Lets hope for the best! "thumbsup"
Click for larger image
