Fallin Apart's BWD 'Low Pro' Wedge Build
fallin apart
NIXA
I got My first comp Mrc last year and I really liked comping with the mini's because of the more even playing field, my latest mini I was comping was a BWD Wedge that just preformed awesome and couldn't wait to try out BWD's new chassis when I saw the Low Pro come out I knew I had to have one so once they got released I picked one up.
Spec:
Axle: Losi Mrc Pro
Transmisson: HR metal gears Hot Racing Hard Anodizing Aluminum Center Gear set for Team Losi Mini Rock Crawler #MRC1000T*-*-By Truck: Team Losi Mini Rock Crawler*-*The Crawlers Store LLC
Shocks: Losi mini T shocks Aluminum Threaded Shock Set(4): MLM | Horizon Hobby
Tires: 1.9 HB Rovers 1.9 Hot Bodies Red Dot Rover Crawler Tires Pair (2)
Servo: Hitec 7955
Radio: DX3S
Motor: Holmes Hobbies TorqueMaster Mini
ESC: Castle Creations micro Sidewinder
Copy Cat! It'll never perform as well as mine. :mrgreen:
Just kidding Austin, I'm anxious to see how you set yours up; it will be fun to comp these against each other.
I already told you that I was getting a low pro and you knew it, so you just had to take my idea. :mrgreen: and I'm waiting to see how you set yours up so I can "borrow" yoursetup
Make sure when you screw the rodends to the lower links you use the black set screw and dont make the same mistake I did and use the silver/chrome one's. Part # on the traxxas rodends #1942
The parts truck
Last years comp rig
put the chassis together, when you put your back lower links on you wont use the screw the the rodends use each other to lock it together
body off shot of last years comp rig,
That has to be one of the most interesting backdrops for taking pictures. Build is looking good, I cant wait to get my own build going.
going to be ordering the High stearing knuckles and alum. C's and lockouts
UTA steering: RcBros Hobbies
Knuckles: RcBros Hobbies
C's: Losi Front Carrier Set, Aluminum: MRC
Lockouts:
Losi 1 Pc Rear Hub, Alum/Steel Axle Set: MRC
Looking good Austin! The parts you have listed above are all my first choice in parts; I run them on my other Mini Wedge and they are top notch. The only thing I would say is to save your money on the lockouts. I had them on two of my rigs, and kept bending the shafts inside. I finally went back to old-school dogbones on my pre-Pro Roller rig, and have found the Pro Roller stock lockouts to be great. Just my 2 cents worth there, buddy. "thumbsup"
I never had a prob. with lockouts my last wedge, plus I like bling 8)
thanks for the heads up though
Got my shocks in the part # losb1289
Just a heads up the short black links are the upper front links
Rodends inplace
