Fall R/C Truck & Tractor Pull - Oct 13, O'fallon, MO
thisdougsforu
St. Louis, MO
Everything is finalized! Big thanks to Travis Sutton and MMRCTPA and Mike Draper w/ CIRCPA. 13 classes, 2 tracks, tons of fun! 5 dollars will cover your entry fee for as many classes as you'd like, and Sutton Motorsports will be raffling off a roller chassis for 5 dollars per ticket as well! We have the ball diamond from 11-3pm. We will be at Westhoff Park (Diamond #7) in O'Fallon, MO. It's less than 5 minutes from I-70 right off the TR Hughes exit.
Class rules with sanctioning club in ()
1.9 Tire Stock 4×4 (SMS Rules)
Chassis: Production Scale 4×4 (SCX10, Hi-lift, Bruiser, etc:)
Motor: 27t Brushed or higher
Battery: 2s Lipo
Tires: All 1.9 Scale Crawling Tires
Hitch: Zip tie around axle permitted.
Weight: No external weight added for pulling. Truck must be as appears on trail.
2.2 Tire Stock 4×4 (SMS Rules)
Chassis: Must be solid axle w/ center driveshaft.(Wraith, Night Crawler, etc:)
Motor: 20t Brushed or higher
Battery: 2s Lipo
Tires: All 2.2 Scale Crawling Tires.
8lbs 17.5 Pro-Stock 4×4 (MMRCTPA Rules)
Chassis: Production or scratch shaft drive
Motor: 17.5 Brushless 550 can, 17t Brushed
Battery: 2s Lipo
Tires: 1.9 scale appearing crawling tire
Hitch: 2.5” max height. Must be 3” from center line rear axle to hole.
Weight: 8 lbs max, weight box permitted
8lbs 27t Pro-Stock 4×4 (CIPA Rules)
Motor: 27t Brushed
Battery: 2s Lipo
Tires: 1.9 scale crawling tire, Tamiya TLT-1, or RC4WD 1.9 Pullers
8 lbs Modified Diesel 4×4 (MMRCTPA Rules)
Motor: 4000 kv, 550 can
Battery: 2s Lipo
Tires: Any 1.9 max 3.75 tall, max width 2.0. V-tread allowed. May run duals on rear if no v-tread. Tires may be cut
Weight: 8 lbs max, external weights permitted if scale.
8 lbs Modified 4×4 (MMRCTPA Rules)
Motor: 6000 kv, 550 can
Battery: 2S Lipo
Tires: Tamiya TLT-1 or RC4WD 1.9 Puller, tires may be cut
10 lbs Super Modified 4×4 (CIPA Rules)
Motor: 7900 kv, 550 can
Battery: 3s Lipo
Weight: 10 lbs max, external weights permitted if scale.
Weight: 10 lbs max, weight box permitted
8 lbs Modified 2wd (MMRCTPA Rules)
Motor: 7000 kv, 550 can
Battery: 2s Lipo
Tires: Tamiya Midnight Pumpkin/Lunchbox, RC4wd 1.9 Puller, TLT-1, tires may be cut
Hitch: 3” max height
Vehicle Length: 19”
8 lbs Super Modified 2wd (CIPA, SMS Rules)
Battery: 3s Lipo
Hitch: 4” max height
Vehicle Length: 19”
10 lbs Pro Stock Tractor (MMRCTPA Rules)
Motor: 5000 kv, 550 can
Battery: 2S Lipo
Tires: MMRCTPA Spec
Hitch: 2” max height
Dimensions:Maximum over all length is 19 inches. Maximum tractor width is 14 inches. Maximum tractor length is 18 ¾ inches. The wheelie bars may be ¼ inch past the rearmost part of the tractor. The furthest point forward shall be no further than 15 ½ inches from the center of rear axle.
Weight: 10lbs max, external weight must be scale appearing suitcase weights
10 lbs Super Stock Tractor (MMRCTPA Rules)
Motor: Any 550 size motor legal
Battery: Any voltage
Tires: MMRCTPA spec
Weight: 10 lbs max, external weight must be scale appearing suitcase weights
4 lbs Garden Tractor (MMRCTPA Rules)
Battery: 2s Lipo
Tires: Tamiya TLT-1 Tires or comparable
Vehicle Length: 12.5
Wheelie Bar: May not extend more than 2 inches past the rearmost portion of the hitch. Wheels may be replaced with skid pads.
Weight: 4 lbs max, external weights must be scale
25 lbs Open Unlimited “Run Whutcha’ Brung” (SMS Rules)
Motor: Nitro or Electric Power permitted (no voltage limit). May use multiple motors. No Gasoline.
Chassis: Production or scratch – must be 1/10 or 1/8 scale
Weight: Must not exceed 25 lbs and must be able to safely hook to sled.
