Highmark
My goal with this thread is to document my experience with my Smith Little Torch and hopefully provide some guidance for those who are looking to purchase one. I don't claim to be an expert on this - nor am I trying to sell this setup as being better than anything else (different types of torches, brazing methods, or even welding). There are plenty of other threads where those discussions have ran their course.
A few years ago I bought the BernzOmatic Map-pro setup like this one: Shop BernzOmatic TS8000KC Map-Pro Kit at Lowes.com
It costs about $55 at Lowe's and is a great way to get started on a budget. Lots of guys have built some amazing tube work with these torches. The handle comes with an ignition button making it very easy to operate this torch and the disposable bottles last awhile.
It works well- but it produces a very large feathered flame and isn't really tunable. My issue with this torch has always been that I end up heating up not only the area I'm working on, but surrounding joints as well.
Which leads me to the Smith Little Torch. The Smith Little Torch is a micro torch that is intended for jewelry and small crafts and it produces a very hot pin-point flame that is well suited for silver soldering work on our crawlers; apparently you can weld with it too. The Little Torch also features a small light handle, and the gas and oxygen lines are both lite and flexible as well. I learned about the torch from Kaetwo and some of the other Utards, but I'm sure that many others on the forum have used it as well.
The torch works with a variety of gases and oxygen depending on what setup you buy. The gases include Acetylene, MAP//Pro, Propane, and hydrogen (and probably some others) which are mixed with oxygen. The oxygen can come in the disposable bottles available at Lowe's, or a refillable tank like a 'B' tank (a 20 Cu. Ft. tank that's filled to 2000PSI). The refillable tanks require a regulator, whereas the disposable tanks use a preset regulator as they operate at much lower pressures (the downside is that they don't work nearly as long). Smith claims that the big bottle will last up to 15 hours with a number 5 tip at 2-7psi - I got my tank filled at a local welding supply shop for $9. "thumbsup"
I got my setup from Weldfabulous.com - and I was pretty happy with their shipping time and customer service. I ordered on Wednesday, and had my stuff by Friday. I wish they would support RCC "thumbsup" :ror::ror: I ordered kit 23-1010P seen here: https://www.weldfabulous.com/p-21276-smith-little-torch-23-1010p-propane-caddy-disposable.aspx Edit 12/20/15 - looks like Weldfabulous doesn't carry the kit anymore. Here it is on Sears: http://www.sears.com/smith-equipmen...SPM10106538725?prdNo=1&blockNo=1&blockType=G1
This kit includes the following:
11-1101C Torch
8' covered hoses
#3, 4, 5, 6, and #7 tips
#249-500 preset fuel regulator
30-20-540 Oxygen regulator
20 cu. ft. oxygen cylinder
#13493 caddy carrier
H698 pair check valves
Here's how it showed up:
I choose this model because I wanted to use disposable map bottles and the refillable tank and it includes the appropriate regulators. The one thing that the kit doesn't include - and I consider necessary is flashback arrestors. I ordered these: https://www.weldfabulous.com/p-21835-smith-flashback-arrestors-regulator-mount-h753.aspx They keep the flame from traveling back and damaging the regulator and / or causing your oxygen bottle to become an explosive torpedo. Note! You need the regulator mounted ones - the torch mounted ones wont work!!!!
My kit also came with five tips, here's my best attempt at showing you the sizes with my cheap camera:
Note the tip on the left is the smallest - it has a synthetic sapphire that the flame passes through.
Close up:
Each tip is stamped with a number to indicate the size:
The kit includes check valves (installed after the regulators) that cut off when the tanks get below a certain pressure:
You'll note that the fuel side check valve is reverse threaded - so you can't install them on the wrong side. They're also stamped to show oxygen and fuel.
Here's the preset regulator for the fuel side - it's a nice piece and installs right on the disposable MAP bottle:
Here's the regulator for the oxygen side (it's pretty :ror: ) - you can see the little check valve installed:
If you wanted to use disposable oxygen and fuel bottles this would be the kit you would need:
https://www.weldfabulous.com/p-7459...jewelers-torch-use-with-disposable-tanks.aspx This kit includes a preset regulator for the disposable tanks and doesn't include the B tank or the caddy. It also includes one tip - whereas the other kit includes five. Just remember those little oxygen tanks go fast!!!
Either way, you're going to end up with this handle:
The valves are replaceable
Here it is with the black aluminum handle section removed:
Tips screw on the end
Also, I guess I should note, that I recommend Harris Safety-Silv 45 or 53. In my experience it really doesn't make much difference as to which one you use. Available here: Lincoln Electric Safety-Silv 45 2-Piece Brazing Kit-45KPOP at The Home Depot
I plan on adding to this post as I go - please feel free to add any tips or tricks that you might have! "thumbsup"
11-1101C Torch
8' covered hoses
Close up:
