Hello,
I'm a general newbie trying to buy a new ESC because the last one seemed to have burnt out completely.
The car runs on two 3.7V Li-ions in series, with a total amperage of 2600mAh, and has a modified DYNS1205 brushed motor (the gear ratios have been adjusted for a slower drive - from its original 4.3:1 to 8.2:1) however, I've struggled to find any specs on the component.
These are the specs of the old ESC.
I don't necessarily want these specs, an improvement on them would be better.
I am looking for an ESC that has forward and reverse with single click in particular, and that can withstand low throttle consistently as the car is focused around articulation.
I bought in this ESC, only to find out that it did not have the forward/reverse with single click - the description was misleading and I had made the mistake of not thoroughly checking the ESCs manual online before buying:
https://hobbyking.com/en_us/hobbywing-quicrun-60a-2s-3s-waterproof-brushed-esc-for-1-10.html
The product most similar to this, but that definitely has single click forward/reverse, is this one.
I'm also looking into this one, which seems even better.
But I don't want to buy without being certain it is compatible with the batteries and the motor.
Does any one have recommendations for reliable ESCs according to the specs I need??
Also, I'm slightly unsure about how continuous/peak amperage works, so the jump between an 20A continuous (old ESC) and 80A continuous amperage (new ESC) worries me slightly.
I'd be grateful for any advice!
