TrailSnail
I decided to build an enclosed car hauler for my SCX10 Rubicon to be pulled behind a high lift F350. The goal is to complete this using hand tools and handheld power tools. No welding or brazing on this project.
Here is what I started with:
1/2 aluminum angle
1/2 aluminum C channel
Pop rivets/tool
Angle grinder with metal cutting wheel
Dremel
Drill
Here is the box portion of the trailer starting to take shape.
I am using continuous pieces of aluminum angle to make the top and bottom of the box portion of the trailer. I mark where I want the bend at corners to be, then cut a 90 degree section out and bend using vise grips at each of the corners.
1/2 aluminum angle
Pop rivets/tool
Dremel
Drill
