Hoosierdady
Fan of wheelspeed
I'm looking at buying this motor and gear reduction combo for a Ratrod build. No crawling, just maybe a wheelie or two and general cruising around on asphalt. Will this setup do the trick or do I need to step it up a notch or two?
12V DC 1000RPM 25mm Powerful High Torque Gear Box Motor Speed Reduction Toy | eBay
Brand new metal gear DC speed reduction motor 25MM 12V 1000RPM
Product description: metal case, metal gears, high torque, low noise, good wear-resistant metal gear, gear has no empty space, long service life.
Widely used in household appliances, audio-visual products, office equipment, health care, beauty and fitness equipment, remote control model, safe box, electric tools, electric windows, high-end toys, automotive automatic facilities, stage lighting, alarm lights, gifts, electronic door locks and other industrial driving devices and so on.
Specifications:
Rated voltage: 12V
No-load speed: 1000RPM
Product diameter: 25mm
Rated torque: 200g/cm
Stall torque: 2kg/cm
Weight: 78g
Shaft diameter: 4mm
Product dimensions: 25mm ( diameter ) x 64mm ( total length )
Specifications:
Rated voltage: 12V
Weight: 78g
Shaft diameter: 4mm
