MikeSSS
I have two old DX5C tx, both have developed problems with the scroll wheel.
Menu choices are now impossible to make, the choice jumps around when the scroll wheel is turned.
Model selection is very difficult, model naming is impossible.
Worse, steering settings, and other settings change to crazy numbers.
Driving and things like diff lock and unlock and lo range high range work well, if you don't change settings.
Any ideas on how to fix this? These radios control 6 different vehicles, most channels used are 5 on a TRX-4. Changing radio brands would require 6 receivers, but it might have to be done. Two transmitters are needed so two vehicles can be driven at the same time. Use is mostly crawling and woods driving, not fast stuff.
RC sailboat guys have switched from Spektrum to Flysky to get away from random hits while racing, so I'm sort of familiar with Flysky.
Anybody know if Flysky 5 or 6 channel surface tx can work with both AFHDS and AFHDS 2A? My FSi6 stick radio can and this is very useful.
Thanks
Thanks
