Servo questions: My ESC/BEC can output either 6.0 or 7.4 volts. My receiver can handle up to 9.6 volts. Running 3s 4000mAH battery.
I need two servos (one for steering, one for gearbox).
I assume both should be the same voltage spec.
Any huge advantage to using 7.4v spec servos over 6.0v? Just speed? (there are fast 6.0 volt servos...) I am just bashing/crawling around, not racing.
Also, for an SCX10 II with stock 1.9 wheels, do I need a high torque servo?
What type of torque/speed should I be looking for? >=200 oz, < .011 sec ish?
Thanks.
Thanks.
