I will not have that much time for crawling next season, so I have decided to build me a "standard sized" Berg for 2014. That way I will have always have something to drive and can play/design/manufacture my other Berg with no rush or pressure.
With standard size I mean it have the same measurements as stock V1 axles so I can pick and choose between many different options and vendors. It also helps if I have to replace something when it gets broken.
Two main questions had to be answered although...
I started to choose among the different gear boxes available and liked the looks of Bulldog gear boxes from ClassiCutCustoms. So I contacted Barry and I ended up with a bit more than just his gear boxes... :ror:
I must say that Barry is an awesome vendor. His service and products is not just great, it is not many that gives you continuing updates how the order is processing. Also he dug up some old drawings of a product I wanted and made it for me!
The other big decision was which motor I should use. This time I wanted real power, so my old small pullers would not cut it. I choose between Brood and Holmes and ended up with Brood. The real deal beaker for me was that I got response from Eddie within 12 h and I still have not heard anything from Holmes.
So lets get back on track... today I received two big packages, so it is time to start my build thread
What could those to contain :?:
First one came with a warning :shock:
and it was true... :ror:
The other package contained a lot more parts
I also salvaged some parts from earlier builds
Dlux Bully style front drive shafts with enlarge tangs.
Axial c-hubs, Dlux machined Bully knuckles and home brewed weight holders for cermented carbide cylinders.
Traxxas Big Bore shocks with lathe bodies, rod end modded caps mini-T springs and JeepinDoug mini-T spring cups. Thanks to the help and advice from Erik Dlux I will also use MIP valves in the shocks. Thanks Erik! "thumbsup"
And of course the sexy RC Bros lightweight gears
I plan the build to end up like below. The only thing I am waiting for right now is the rear axle shafts, the wheels and to deiced which lipos to run.
Front Axle:
* ClassiCutCustoms Bulldog Berg gear Cases
* ClassiCutCustoms Bulldog Berg delrin axle tubes
* RC Bros 7075 aluminum lightweight lockers
* RC Bros 4340 steel lightweight gears
* Berg V1 small second and third gears
* Robinson Racing 14T pinions
* Dlux Bully-style universals (modded with a bigger tang)
* Dlux machined Bully knuckles
* Axial AX10 aluminum C hubs
* ClassiCutCustoms ”Bigron” behind the axle electronic mount
* Homebrewed over the axle battery mount
* Homebrewed front axle weight holder
Rear Axle:
* CBRB Fab Titanium Berg lightweight rear axle shafts
Chassis/ Suspension:
* ClassiCutCustoms Bulldog Pitbull 2.2 Pro
* ClassiCutCustoms Titanium lower and upper links
* Dlux delrin link sliders
* Traxxas 3.5” Big Bores, lathe downed with cap mod, pink Mini-T springs, JeepinDoug Mini-T cups and MIP valves
* Wicked Monkey Design skin
Electronics:
* Brood Conflux, cobolt magnets, ST-HHK 30t Armature
* Hitec 7950
* Dual Sidewinder micros
* CC Bec
* Sanwa RX-471 receiver, decased and modded with 90 degrees pins
* Lipos to be decided
Tires/wheels:
* 5th Dimension Negative Space Titanium glue on wheels
* VP SLW hubs
* Homebrewed LaaLaa skinny Rovers
* Crawler Innovations Double Deuce 5.25” comp cut inner foams with soft outers and tuning rings
But, now it is time to head back to the building, so to be continued... :mrgreen:
Front Axle:
Rear Axle:
Electronics:
* Hitec 7950
* CC Bec
Tires/wheels:
* VP SLW hubs
