How did the set screw back out? Is the mount stripped? The scew is threaded into both sides of the double sheer mount. I think it is a quite nifty selflocking design. Pictures of the upper mount would help.
Sent from my Moto Z (2) using Tapatalk
It peeled the screw out & stripped the plastic. I just moved the upper to the 2nd set, haven’t had an issue since. Also went down in shock weight.
Been a while since my last lost. Work got crazy & w my little free time I’ve been spending a lot of time in sim racing ( iRacing, AC, RR3, etc).
So I broke out the RCs again, lately. Noticed the rear right axle shaft is tweaked. Damn. Guess I’ve got an excuse to upgrade [emoji23]. It still seems bouncy as hell! I’ve got hard pack dirt, with a loose top-layer in the back yard with smallish rocks (I live in th desert). It gets really squirlly & the ass end bounces all over the place. I feel there are a few problems.
First, tires. Stock rubber, VQ method wheels, PL crawler 2-stage foams. Hoping the foam breaks in more but wonder if I should go Hyrax, Super Swampers or BFG Baja tires that PL has?
Second - shocks. I’m going to upgrade the upper mounts, I would like to continue using the King shocks for now, but the spring feels too stiff. @ full adjustment, the truck doesn’t sag much under its own weight (dumped th spare tho). Front shocks feel like there’s virtually 0 travel. They squat a reasonable amount tho.
Third - Axles! I am seriously considering open front diff w heavy weight fluid. Locked front puts added stress on front components when turning. Again, the mindset of this is U4 style driving, where ever looks cool to take it out. I’ve made up a simple course in the back yard that’s good to sit back & drink beer to. Has a few bricks to climb over, cement slab to launch off into a high speed down hill, right hander, back stretch, right hander, up hill, then a req right section that requires climbin over some more bricks, tight 180 & down the slow start/finish/Beer table. [emoji1305]
I plan to pick up some small 5-10” size rocks from around the riverbeds & hills to create small rock gardens for the slower portions were im climbing over bricks.
Free times up, gotta get back to work. Have a couple other things to bring up but hopefully can get some more input on this bounce issue. The spare may help combat the bounce but that comes at the cost of higher COG & more high speed roll overs.
Sent from my iPhone using Tapatalk Pro
