Rocksmith Eng.
You know guys, I just spent the last 4 hours tinkering in the shop.
I studied the cvd's for quite a while as well. Even did a lil tweaking to mine just to see what would happen.
First thing I did was to cut a bit of a chamfer on the inside lip of the cup. It changed the angle just a bit. But what I did notice is the cross pin was now the limiting factor in the angle. While holding it full angle and spinning the cvd i could feel the pin, and it would reduce angle a bit then spin free against the cup again.
What this is tell me is that the cup is sized to limit the pin from being the limiting factor. If it is off just a couple thousands (which I doubt it would vary more than +-.001) and someone has the steer servo to get every degree out of it you can get. Yes the cvd is gonna explode.
I have been running mine for quite a while now. When I set my end points on steering, I went as far as I could and then backed it off a bit.
The knuckle on the rig will turn more than the cvd will.
So back off the end points a bit and see what happens guys.
Just my .02
And yes I am working on Ti axles................
Just my .02
