Can anyone tell me where to get the steering stops for this thing? Just picked one up and I am hoping to avoid breaking the front axels on my first run.
Are you solder on my drivelines to keep the spring clips in place.I’m really happy with my SG4C. It’s a great looking, very detailed rig. Was very easy to build. However... I was a little disappointed with the stock model when compared to the Ascenders, SCX10s, etc in crawling capabilities.
So, I double stacked weights in the wheels (more then 8oz per wheel) and installed the cross axle weights. Also pulled the Foam from the spare tire and removed the faux engine plate to help reduce a tiny bit of top weight.
I just installed the RC4WD King Shocks and the Cross Rc shock relocation brackets. The shocks seem a little too soft, but I’ll update after a few runs. Also need to install firmer foams. The thing weighs almost 10lbs now.
YOU NEED TO WRAP TAPE OR HEAT SHRINK AROUND THE KEEPER SPRINGS ON THE DRIVESHAFT. I lost a driveshaft when the keeper spring popped off and pin fell out.
I Definitely want another (maybe the SU4 )
I apologize for maybe changing subject matter on the SG 4 Demon, but II just built the "C' version. and took out for first run on a fairly difficult and agressive (rocky) course. 10 minutes into the run, the main drive shaft slipped off motor shaft. Guess I need to put a drilled dent into motor shaft to receive cup set screw( it was thread locked). Ok fixed that and continued. One hour later, the left front CV or "u" joint to the wheel broke and I had a free spinning wheel. That ended my day . I wondering if anyone else has had similar experience with this quite expensive truck. All metal parts etc, I was expecting more durability. Oh yeah and the metal frame mount tab ( for rear torsion bars)at the transfer case frame bent as well. Ive got an Axial SCX 10II ( at half the price)that Ive run for several month on same course with essentially no damage except cosmetic. I'm quite disappointed. Truck looks awesome and after some creative shock work, I think its not near as top heavy as it was and is a bit more stable and less likely to roll. Tires are way too stiff with that mini cell foam inner core I think too. Would love to here from anyone with experience with the truck.
The SG4C battery box is small but these fit.
