Cross RC Demon SG4C kit
Hobbywing 1080 is waterproof, so that's good. No servo is waterproof from my experience, even if they claim to be. Personally never had an issue with any servo in water tho(knock on wood). Receivers are easy to put in a balloon and place a zip tie around the wires.
Can you tell me the brand/model of the batteries and where you got them. I ordered my demon but it's going to take a wk before i get it and i want to order the batteries. I want to make sure i order the batteries that will fit.
Thanks for the battery info. So you've had your SG4C for a bit. How do you like it so far? You were having a bit of an issue with it being a little top heavy. Have you been able to correct that?
I'm working on it, but it's not where I'd like it to be yet. I'm adding 8mm brass hexes to widen the trackwidth a bit and also need to play with different shock springs and reposition the rear shocks so they're more outboard. It's definitely a flex monster in stock configuration.
Even though the axles and trans are prebuilt, there is a lot to keep you busy with this kit. So many bits and pieces!
TrailDawg, yours looks great. I just got mine in the mail today maybe after work i can get started on it. I hope mine turns out good as this will be my first kit. Cant wait...
How did you tuck/ run all of the wires? Seeks to have a lot of whites and candy fit all up front without it being a sloppy mess
Sent from my SM-G965U using Tapatalk
