Hi guys! New here... I’ve been contemplating making a huge purchase for a Xmas gift for my son so he and I can build away over winter break.
This is a great build thread so thanks.
I’m hoping you guys could recommend the top additions I should purchase so we don’t get stuck with needing things like the thin washer/shins you mentioned.
I see servo size is important as many don’t fit.
Do you mind giving me a short list of things to get for this kit like the small washers etc since you’ve had time to work out all the minor adjustments?
Thanks a million.
Well that sounds like an awesome gift. I hope he's old enough to appreciate it.
Disclaimer/warning If you purchase the parts I recommend below this will become a quite expensive project. Due to the weight of this rig you really shouldn't skimp on the electronics.
You need 2 strong servos the stronger the better. The spacing of the servo can be adjusted easily with some styrene or plastic scraps. I used the Savox 2290 which aren't cheap but they're about as strong as they come.
You'll also need a ESC, I would recommend the Castle Creations Mamba Monster X. You might need some wire and bullet connectors depending on how you wire the motor.
You'll need a receiver with lots of channels, how many? well that depends on how many of the features you end up using. I went for a 7 channel receiver which meant that I needed a new radio as well which also wasn't cheap.
The washers were just generic hardware store washers, just look back at my old posts for the specs.
to glue up the body you'll need some type of plastic cement like bondene (it melts and fused the parts, its not actually a glue)
I'm sure I'm forgetting a bunch of stuff though.
