Jason MC
This is a brand new Creeper build but done ready for the comps. The pic shows a stock creeper "green" on the left and the modded creeper"red" on the right. The rear tires are butted up at nearly 90 degrees. The stock creeper green is hanging in the air up front and the modded red creeper is on the ground. The other pics show the setup and yes it is sitting there twisted up on it's own. It sets at around 86 degrees by itself. This setup is super smooth. 70 mm upper links but shimmed for perfect caster and pinion angles. The top battery tray is cut down to tie the tranny to the side plates and lock it all in solid. No need for a cross over bar up front with that done. Body has been trimmed alot to clear the crazy twist the creeper has now. I will finish her up with some new ellectic's and be ready to comp. I also had to change the link rod ends around to clear the rear shocks due to the travel. The rear link have been flipper to the front as well.:mrgreen:
