<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:ApplyBreakingRules/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> Hello all
Am pretty new to the crawler world, but just picked up a MaxStone 8 to get started, but I think I might like to replace the stock motors.
From the info in the documentation that came with it, for the only info it had that I think matters is that states it's a RC540. Which I gather is a frame or some other physical motor size thing. IE: most 540 motors should bolt into that same mount?
But then on the internet when searching for just the motor, I saw info in one place that also said it was a 70T or turn I gather.
So first off, was kinda hoping someone could explain (aside from the obvious of that its a number of turns), what the "turn" point for these motors means or matters?
An then two, if anyone has any recommendations for a replacement, would be glad to hear it.
Btw just to mention on that turn thing, I was looking at the Holmes brands, an saw that some of their recommendations for crawlers are to use motors with what I think are 13T windings? Where as the factory one is a 70T?
Guess its stuff like this that has me confused?
Thanks for any help
<!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]-->
Thanks for any help
