As I feel my TRX-4M Defender is setup the way I wanted (Overlander/Crawler) and taking on the challenges of a heavy body, I think I've been successful in making it the best possible 1/18 scale Defender in the most practical way. I'm still waiting on a decent all-in-one brushless motor from Hobbywing or a plug-and-play setup from Holmes while retaining the stock ECM. The new Furitek looks rushed and the cable management just looks like a rat's nest to me.
That being said, I've started my Bronco project to make it into a pseudo Baja style Bronco where speed and handling take priority, which is on the opposite end of the spectrum compared to my Defender.
To start, the Bronco comes stock with the following spring rates from the factory:
Fronts: 0.095 Rate [TRA9758]
Rears: 0.095 Rate [TRA9758]
What is amazing is that the Bronco comes with a near perfect 50/50 weight distribution out of the box, which make it a fantastic candidate for anything really, moreso than the Defender.
I've spent long hours and several days on tuning the car through piles of rocks, pebbles and jumping it off some ramps to high-grip, lateral turns to the point where the stock servo and shocks had died.
Based on running the stock model into the ground, I've come up with the following parts to improve/reinforce the Bronco to meet my goals.
Electronics
- Traxxas Pro Scale LED Lights [TRA9783]
- REEFS RC 99 Micro Servo x DSM Off Road TRX-4M Servo Mount
- REEFS RC SHORTY Micro Horn
Body
- Traxxas Lower Links (Steel) [TRA9749] [Swapped with the Defender]
- Traxxas Hardware kit (Stainless Steel) [TRA9746X]
Internals
- Traxxas Sealed Steel Bearings
Suspension
- Traxxas Shocks w/30wt OEM Shock Oil
- Traxxas Springs - 0.095 Front [Stock] + 1 Clip / 0.095 Rear [Stock] (w/2x Preload Clips)
- Traxxas Shocks, GTM, Orange [TRA9764-ORNG] [On Order]
- Traxxas Shocks w/50wt OEM Shock Oil [On Order]
- Injora Steering Blocks (Brass)
- Injora Caster Blocks (Brass)
- Injora Steering Link (Brass) [On Order]
Powertrain
- Traxxas Speed Gear Set [TRA9776X]
- Injora Axle Covers, Brass (Front + Rear)
- Injora 6mm Wheel Hub Extenders (Brass)
Wheels & Tires
- Traxxas Canyon Trail Tires [TRA9769]
- Traxxas Method 105 Beadlock Wheels [TRA9781-BLKBL]
- Traxxas Wheel Weights (Brass) Front and Rear [TRA9780]
- FubberStufferz V24 TRX SlymeBallz
Misc
- Jim's Bearings PTFE Coating for Axles Shafts, Stub Axles, Stub Axles, Transmission and Driveshafts
- Jim's Bearings Waterproof Grease for the Axle Gears and Transmission Gears
