I finally received the lipos i was waiting for, so i took some time to work on this project.
I decided tu put the transmission back to its original position ie with the motor in the front, and to cut the chassis plate a bit more to fix the new "rollcage" made of 3mm delrin lower.
These roll bars are much lighter (8 gr each) and should help with the cog.
As the new skid i made moved the mount points for the lower links, i had to shorten them in order to keep the same wheelbase.
I also cut the previous skid down to "delrin french fries" :
i then drilled and filed them to make a set of chassis brace.
I made a lexan tray for the esc, and used it to hide some wiring as well.
I sticked the bec to the front side plate of the transmission case using some 3M Dual lock
I also received another cheap towerpro servo to replace the previous one that broke down, got it installed but still need to make a steering rod to get it working.
I opened the Futaba Rx case and tucked the antenna wire inside, i will see how it behaves that way.
Here are some pics of the rig at the moment :
With the small lipos it now weighs 2420 Gr / 5.3 lbs with 57% of the weight to the front.
I still have to tear apart the shocks to smoothen the rear suspension travel and to make some lexan body panels.
I have just one tiny problem with this setup, the tranny case with the motor at the front requires a longer front shaft to work properly, while checking the suspension travel i had the unpleasant surprise to see the male side of the front shaft pop out :x
So i'm currently waiting on some longer junfac universal to fix this problem and to start fine tuning this build once again.
To be continued ...
To be continued ...
