Hwheeler73
So the rear axle bearing caps need to mount to the front version axle tubes. They weren't designed to do that. So you're going to grind the ends of the tubes down slowly, checking often as you do, so that you can slide the bearing caps on far enough that the screw holes line up.
Sent from the great unknown!
