Gavin Ayala
Close up look
They do have sidewall reinforcement lugs
I cut the sidewall support lugs out with a flush cutter and used a leather hole punch to punch 4 2mm holes. I highly recommend cutting the sidewall lugs out of any tire to soften the rubber which increases traction and allows the foam and tire to work in harmonious balance. Also if the tire is not VENTED the foam and tire CANNOT conform resulting in a air tight stiff tire. I recommend a minimum of 3 vent holes in a tire. The more vent holes to a tire the softer and faster the tire / foam can conform, compress and decompress.
