That looks great! Do you have more pictures of that paint? Looks good.
Also curious about those Rancho shock you got for the steering stabilizer too.
This is on a TRX-4 chassis? Impressive!
Hi mate,
I had the bodyshell professionally airbrushed. The colour I chose was Candy Blood Red from the Autoair range of paint.
The Rancho twin steering stabilisers were custom made using extra long rod ends, some white vinyl wrap, the bendy part of a drinking straw and some vinyl logos.
This is on a Carisma SCA-1E chassis. I used MST MSA axles to get the wheels/tyres to tuck. The MST axles reduce track width by approximately 30mm over a standard crawler axle. I'm guessing you could do the same on a TRX4 to achieve the same result.
To get the lower ride height and incorporate the drop bed I changed the shocks to 75mm on all corners and did a partial delete of the rear shock mounts.
I will throw up some extra photos to let you see the paint colour in all its glory during the build process.
1. This should give you a better idea of the paint, it really pops in bright light
2020_0501_16323900 by
Stuart Pardue, on Flickr
2. little bit of Americana on the rear window (custom made by myself)
2020_0704_20190100 by
3. even on 75mm shocks she can still flex and also show off that tyre tuck properly
FB_IMG_1595071290129 by
4. pretty much the final stance and showing the dropbed in place. Note the dropbed is sitting on the chassis rails so physically can't go any lower.
Roll bar is a 3D print for the much wider RC4WD blazer body but I cut and shut it to fit the F150
FB_IMG_1595785754099 by
My goal for this build was to get it as scale and realistiv as possible. Even the tyre choice was planned to replicate a real life 33'
If you want any other details feel free to ask.
