TITANIUM94010
While making custom builds, I find that I need to find something to do that requires less constant head-scratching and frustration, and swearing like a sailor :roll:,and just something nice to sit down, relax, and wrench on. I'm still expecting to do some figuring out, but it'll be a lot more laid out and straightforward than trying to figure out how to mount a trx4 diff to a slash ifs, and having to constantly reach for the dremel to make slight adjustments.
After looking at the possibilities, I think it's time for me to finally make an actual performance crawler for once, only problem is, I don't have much of a clue as to exactly what to do.
I've got some random parts in the parts bin, not too much
-Complete Trx4 Roller minus rear axle
-Ar44 front and rear axle housings, no gears
-Assorted links
I also have tires, foams, and radio sorted out. No wheels or body, but I may just 3d print them.
I'm thinking of using a TRX4 as a starting platform, considering that I have pretty much a complete roller, but the problem is the stock frame rails and transmission probably won't be used and swapped for something lower CG, but I do want to use TRX4 axles for portals.
I'm not exactly knowledgeable when it comes to comp builds, and after digging around some comp build threads, the amount of frame and transmission choices seem to be unlimited, every new thread seems to have some new frame rail or transmission.
Heres my plan so far:
Pick up another TRX4 front axle for 4ws (It'd be nice to have for normal driving around when not doing comps, and I can lock it out)
Get a low cg comp rail and chassis, use stock TRX4 shocks. I also have a 3d printer so I can make parts from that.
Could I have some recommendations and tips from the more experienced guys out there? G-Speed seems to be a very popular option for custom chassis rails, but I've also seen builds using the TCS game changer, sherpa rails, and Toyszuki, What are the advantages and disadvantages, and how compatible are they with TRX4 axles? If there are more options that you guys think are better, please post! The transmission I'm looking at is the TGH2. low, but I find it to be too expensive, so recommendations for them would be helpful too.
Thank you!
-Assorted links
Thank you!
