So I have the Bronco Ascender and I was thinking of converting it to a monster truck. I posted elsewhere and got a couple tips but I need to make sure I'm fully schooled on my choices before I start spending money.
The Bronco wheelbase is 10.75" so I'm thinking tires that are around 5.35". The two options I've learned of are the HPI wheely king tires and the Proline Destroyers. They are fairly close in size but the Wheely king tires are pretty cheap so that might be the obvious choice. Not sure if the Destroyers are better in any way. Thoughts?
The next thing are the wheels. The axle is 7.56" face to face. I haven't fully decided if I'm going to stick with the bronco body, but I'd imagine the bronco body is wider than most other bodies out there. With the fender flares the bronco body is 9.5" wide at its widest point. The wheels will definitely need to be offset. Honestly, there's probably no amount of offset that will be enough to get outside of the bronco's fenders. I'll probably have to go with a new body. Suggestions? I might just do a pickup. Not sure what width I should expect. I have an old one here that's junk and it measures 6.75". The wheely king tires are 2.75" wide. So I might need something close to a 1" offset. Does that exist? Someone suggested the Traxxas 3672 but I'm not sure what the offset is on this? Anybody know?
Lastly, it's suggested that I will need to get the bronco lifted. How do i go about doing this?
Thanks in advance!
Thanks in advance!
