brianw's portal Optic
brianw
RCC Vendor
Vendor
WV
All I have is electronics and a "plan" at the moment.
  • HH 3500kv puller pro
  • Castle Copperhead
  • 2.2 wheels with 1.9 Tusks
  • Dlux Fab 80mm shocks
  • F10 Portal Axles
  • VFD Twin Transmission
I'm going to print another Knight Customs set (interior, engine, terra bug) but I have no idea what color scheme I'm going with. I have a black cage on it's way.
I'm also working on a Portal H10 Optic using the VS4-10 portal kit as a parts donor (plus a 2nd front axle for the rear). So far I'm not convinced its a great fit for he H10 optic as the portals raise the rig up 12mm and there isnt space for the portals to tuck up/into the cage when lowering it back down. But I'm still working on a few ideas to make it work.
I mocked up some Boss shocks with the offset mounts that drop the rig 12mm and the link mounts hit the cage in the rear limiting the travel of the shocks by 10mm (out of 22mm).
Next thing I'm going to mock up is a set of 80mm shocks to see if that can help with clearance and lower the rig.
All that said if you dont mind the rig being raised a bit this can totally work. It will also simplify it a ton if you use a rear portal axle in the rear and not a front axle.
I havent mocked up the transmission yet but I do plan to use the shorty conversion kit (because the servo wont clear without it). I also plan to use either a modified VFD skid or the VRD skid (just be aware the VRD uses a different mounting hole spacing and link lengths). I also ordered the servo mounts that Scale Metal Supplies makes to help make the VFDT more compact VFD Twin Servo Plates.
EDIT: only the VFD twin skid has the right bolt pattern and placement because the twin is wider at the transfer case.
One other thing to note if you try this and a 4WS setup, the rear axle wont have enough triangulation to keep the axle from moving side to side. It helps a fair bit if you outboard the rear upper links on the skid side (like the front axle). I may try designing a new piece that goes between the skid and cage that will outboard the links, provide a double shear and prevent those links from being hang up points.
I could post a few pics if anyone wants but I dont want to hijack the thread anymore than I already have.
Hijack away, won't hurt my feelings at all lol.
I plan to run the portal rear axle, I don't need/want rear steer and I was thinking desert lizards in full droop to try to bring it down a little. I haven't even begun to think about the skid or links yet. I'm not even 100% sure I'll use all of the functions of the twin...
I've been reading JMo's thread over on the other site - Optic-al Illusion - good info.
not much in the way of updates, but I did assemble the axles today and I hope to assemble the trans tomorrow. I ordered the VFD twin skid plate and decided on tires - 1.9 jconcepts Tusks; they're on order as well.
I still haven't decided on what body to run...thinking I may print the Poorigin hood and doors...maybe terra bug roof and rear engine covers? Teal or teal and purple? who knows...
Well I'm glad you didn't try using a VRD or regular VFD skid like I mentioned trying. The bolt pattern and placement is different so you really do need to use the VFD twin skid.
On this skid you still need to use the shorty conversion kit and cut a bit off the front of the skid so the servo clears. I heated up the front of the skid and bent it upward and then cut it. Although before bending it I laid out the front mount point that goes to the motor plate, its 24mm back from the stock hole and centered between the 2 fake socket heads.
I’m way over my skill level on this but I’m gonna give it my best shot…
Axles and trans are assembled. I’m waiting on wheels, tires, shocks, and skid to show up.
I’ve never really built links before and I have no idea how I’m gonna set up the steering up front. I didn’t really think this through lol.
Part of the stubby conversion kit is a servo on axle mount. They also have a aluminum version. I'm using the plastic version from the conversion kit.
You could try using the chassis mount for the servo but then you need to figure out the correct length for the panhard link, if its off you will get bumpsteer. I like servo on axle setups when customizing rigs because you never need to think about the steering geometry.
I just put everything together using some shorter links for the front uppers and I ended up at 13 1/2" wheelbase, stock is 13 1/4". I may just keep it like that. I decide to forget about lowering the rig for now while I work out all the other kinks. I was also thinking if I did lower it the full 12mm the link geometry would probably suffer. Also to get it down 12mm the cage would need to get cut in some pretty structural spots and would need to be re-inforced.
EDIT: the VFD twin will definitely take away from the space for the battery so it will need to get relocated (or downsized maybe?).
If I use the stubby kit, I won't be able to run the Puller Pro...I think it says 35mm max motor length. My skid should be here tomorrow, so I may get a better look at it this weekend.
I only looked at this briefly today, but it looks like the twin will fit behind the servo mount. If there the case, maybe there’s a chance it will fit behind a BTA servo? I ordered a mount from 1Tenth RC today.
B-Mow’s photo
I think the BTA servo location was close to working for me but maybe 1/4" too long. It should clear the CMS mount fine though.
I bet if you ran without the spur gear cover you could make the BTA servo work along with cutting a bit off the front of the skid.
EDIT: you might need to sell me those bump stops though ;) lol
In order to fit the panhard mount the driver side bump stop needs to be removed.
