Thanks for the reply.
I've been looking real hard at the XOR lately, but whish they were a bit taller/narrower, I might import a set (nobody sells RB or CI here
) with 1" wheels and tall CI foams to stretch them out a bit like I've seen done in some other threads.
So far I've tried: Axial R35 Ripsaws (stock tires), RC4WD Mud Slinger 2 XL and the Prolines TSL XL, all are mounted on their own Axial bead locks with 2 oz in the front except for the Ripsaws since they are glued and I also have 3 oz added to the front axle under the servo.
The R35 Ripsays are fairly good all rounder, from snow to sub zero dry rocks, they did ok'ish, got hung-up often, this might just be me learning to crawl, but like with any new toy, daddy gotta change the rubber! :twisted:
The Mud Slingers 2 XL are by far the coolest looking on the Wraith, give you that extra bit of clearance, but the thread pattern is to closed up and the thread blocks to tall/flexible to crawl well even if the compound is very sticky, the thread blocks just flex instead of hooking up and the tires spin and spin and spin. I seen alot of people on here remove every 2nd thread block to make them crawl better, but I just can't get myself to cut a tire with less than 4 pack on them.
The Proline TSL XL are a lot better than the MudSlinger 2 XL, look descent, are as tall, thread block heigth is shorter than the Mud Slinger's and about the same as the Ripsaws. They grip dry rocks as good or better as the Ripsaws for the mix we have here in the Ottawa/Gatineau region, but they tend to spin when the back wheels are looking for grip against a straight ledge and the front does the same above, the skid not hung-up.
When I compare videos of Hot Boddies Rovers and Rock Beast XOR they both seem to be able to push straight up or drag with just the fronts. I think the center thread pattern on the TSL XL might be a bit too closed up as well, but like with the Mud Slingers, I dont feel like cutting a new tire "just to see if".
Same as when I was racing my 2.5RS (hence 7 sets of wheels/tires), each thread pattern/compound/carcass design has it's specific application, where the OEM, usally spent million in R&D before releasing for sale and is a balance of key elements.
Nice video, awsome incline capability, something to aspire to in my Wraith as I upgrade components."thumbsup"
BTW, what's the current weight of your rig and oil weight are you using with the GTR rear shocks?
