bilinvic
A few more changes to the R1:
Now that I have the Wrapter front end mod done, I can use the large JConcepts' Ruptures tires stuffed with Crawler Innovations Double Deuce 6.0” Standard Inner / Medium Outer Foams. I bought a new set of Gear Head RC 2.2 CAC EZ-Loc Beadlock Wheels in black Delrin and transferred the rear .500 hubs over to these wheels. The advantage to using these wheels on this machine is that there's no body work to interfere with and even more ground clearance.
New GMade Lexan panels painted Tamiya Bright Silver backed with gloss black. These panels are temporary though, I have AMF's Aluminum side panels and hood ordered with some graphics to match the PS roof.
I used the Axial Aluminum hubs up front because the stub axles are longer. On the rear I used Yeah Racing 5.5 mm aluminum clamping hexes (blue) because the GMade stub axles have a shorter threaded section. I may perform a similar mod as the front stub axles with the Axial Wraith rear axles to get longer threaded areas for the wheel nuts and greater strength.
I also picked up some 2200 mAh 3S 50C LIPOs that fit perfectly from my LHS. I will have to do some testing to see how long 2200 mAh batteries gives me so that I can have plenty of endurance for a full day of crawling with the group.
