More parts and update:
I received the DravTech Wrapter conversion parts; these are my first 3D printed components and they look and feel very nice....hopefully they are torture tested!
Parts list:
DravTech Wrapter Conversion Kit
Vanquish Wraith Scale Chubs (Clamping)
Vanquish Wraith Steering Knuckles
Fast Eddy Bearings including the larger 5x9x3 and 5x10x3 bearings for the Wrapter parts
Axial Wraith Universal Axles
Axial Aluminum Hex Hubs (12mm)
Axial Flange Pipe (4)
K&S 5 mm x .45 mm Aluminum Tube
Vanquish Wraith Titanium Upper Link (Drag Link)
Unkown brand Tie Rod (from my spare parts)
Traxxas Jato and Revo Rod Ends
Misc shims, spacers and hardware
The front end conversion was pretty straight forward, the most time consuming part was modifying the universal axles. Taking your time here will yield a tight fit on the lower portal gear. I used J-B Kwik to affix the the aluminum tube to the axles IOT achieve an OD of 5 mm.
FYI, here is the link to DravTech's instructions:
http://www.rccrawler.com/forum/axles-trannys-t-case/496243-dravtech-presents-wrapter-gmade-r1-portal-axles.html
It took a while to configure the tie rod and drag link, luckily my parts box has quite a few options. With the parts I used, the steering radius is maxed out and there is absolutely zero tolerance issues - Mission accomplished! At the same time, the axles are drastically stronger with proven Axial Universal Axles.
The overall width is now 12.5 inches using HPI Hot Bodies 2.2 Rovers on Gear Head RC 2.2 Five Star EZ-Loc Beadlock Wheels with stock hubs. The rear width is also 12.5 inches using the same tires and wheels but using Gear Head RC 6-Lug Aluminum Hubs, Plus .500 to achieve the extra width.
I also performed the underdrive mod for the rear differential using the Sawback ring and pinion. 32t/17t front ration and 32t/14t rear ratio. This link shows how:
http://www.rccrawler.com/forum/g-made-crawlers/494709-underdrive-r1-finally.html
Now I just have to get out and test everything before I get 'er out for a full day of crawling with the guys.
