bilinvic
There's something about the G Made R1 that intrigues me and I have been wanting one for a while. I've done lots of research on this machine and it seems to get a mixed bag of reviews, which to me means I can make this R1 work for me; that's the plan hopefully!
My passion is crawling and I have other RC's that are incredibly capable crawlers so the R1 has to prove it can play with the "big boys"!!!!
I was ready to order a new R1 with all the G Made options, but as it turned out, an old co-worker of mine was selling his (I didn't know he had one) so I scooped it off of him for a bargain, and it came with many of the option parts. The only problem was, it was never maintained. This is the first used RC I have bought and I thought it would be fun to do a full restoration/rebuild to my specifications.
The challenges for this build is the limited amount of room for electronics and battery and I want to avoid having the battery mounted on the front axle because it takes away from the scale appearance. I can live with the servo as there's no other option.
The R1 will be fully waterproof in preparation for our rainy winter season. I may eventually go 4 wheel steering but I want to prove the machine's capabilities first.
Here's the list of option parts the R1 came with:
G Made Hardened Carbon Steel Universal Shafts
G Made Adjustable Aluminum Link Mount (Front and Rear)
G Made Aluminum C-Hub Carrier 7 Degree
G Made High Clearance Links
G Made Aluminum Shock Braces
G Made Adjustable Upper Link Mount (Front and Rear)
G Made One Piece Knuckle Arm
G Made LED Lightbar with Connector (Two Lights)
G Made LED Lightbar with Connector (Three Lights)
G Made Axle Skid Plate (Front and Rear)
G Made R1 Delrin Skid Plate
And here's the list of parts I have ordered from RPP to rebuild:
Axial Aluminum Hex Hub 12mm Black (4)
G Made Aluminum Straight Axle Adapter (2) for Rear Axle
G Made Heavy Duty Front Steering Rods
G Made Low CG Battery & Servo Plate for Front Axle
G Made 3x10mm Step Screw (4)
G Made R1 Bevel Gear Set (32T/17T) (Front and Rear)
G Made R1 Front Drive CVA Kit for R1 Axle (2)
G Made R1 Front Portal Gear Set
G Made R1 Rear Portal Gear Set
JunFac Universal Shaft 5mm Replacement Parts (To Rebuild the Driveshafts)
Team Fast Eddy G Made R1 Rubber Sealed Bearing Kit
Team KNK G Made R1 Stainless Hardware Kit
Other parts being used:
RC4WD King Off-Road Short Course Racing Shocks (Slash Rear) (110mm)
Vanquish Products Wraith 3/16 Diameter Titanium Upper Links
Traxxas Rod Ends/Hollow Balls (12ea): Jato
Traxxas Sealed Receiver Box Rustler,Stampede,Crawlers
Mamba Max Pro (Waterproofed)
CC 10 amp BEC
Spektrum SR410 4 ch RX
HiTec 7955TG Servo w/ Axial Clamping Servo Arm
The wheel base was extended; the stock WB is 12.2" and now it's 13.5". This was accomplished replacing the lower links with Vanquish Wraith titanium upper links combined with the longer Traxxas Jato link ends. The stock G Made upper aluminum links were lengthened by also using Traxxas Jato link ends. The one nice feature of the R1 is the number of link mounting points that are available for tuning the suspension.
The R1 transmission doesn't have parts that are upgradeable....and this doesn't work for me. A beefed up Wraith Transmission is now mounted to the Delrin skid plate. The transmission sits on 1/8" spacers in order to clear the lower link ends that mount to the skid plate. The JunFac divehshafts will be rebuilt with new parts....although, I may have to order some alternate JunFac driveshafts if the lengths I have on hand are not sufficient.
A major priority is having batteries that are located within the caged chassis, situated as low and forward as possible and with as much mAh as possible. Let me tell you, that is a tall order for this particular machine! Normally, I run 3S in all my crawlers with brushless sensored motors, but for now, I am going to go with 2S for the R1 with a Holmes Hobbies 35t Torque Master Pro 540. Luckily I have a pair of Traxxas 2S 2200 mAh LIPO batteries from my son's Mini E-Revo that I can use for test fitting. It took a number of hours of testing out multiple configurations, but I finally got it down to where I can mount both batteries and run them in parallel for a combined 4400 mAh of run time, which I estimate will be approximately 2.5 hours. They are as forward and as low as possible without having interference issues with the front upper links in full compression. They are also very easy to swap out for fresh batteries out on the trail.
The Traxxas RX box and MMP will sit on the rear custom "shelf" and will be covered and protected by a custom vented roof panel.
Enough words...here's some pics. The first four is how the R1 was from the day I took possession of it.
CC 10 amp BEC
