Ran into a new issue with the rear sway bar. I've had the bar on and off multiple times as I work through the build, and as I went the arms seemed to keep angling in more and more.
Well, big shock, the cheap Amazon sway bar that I already knew was junk (only using the aluminum arms) is in fact more junky than I even realized. The hole has ovaled out on the machined side of the arm causing it to angle in when tight. I'll be picking up a new sway bar (reefs or hot racing) to replace this.
