Thats exiting...I follow this thread since the beginning...awesome!
Thanks man. I've made some progress, and found 1 somewhat significant issue to resolve so far.
The chassis went together pretty easily. I did download the manual as some of the parts weren't clear of how they connected. The bomber skid plate didn't take much effort to sort out and match the new chassis. I widened the design by 4mm, extended the rear on the sides a bit for the rear mounting point (to the cage), and added the center mount hole. I had a friend print the skid on his bambu (1.5hrs vs 5 on mine). I was able to reuse the side plates. I also made some small sleeves to fill the mount points in the cage.
The only problem so far, and the reason it's not a roller yet, is the rear shock mounts. Apparently the lower link mounts on the Miller axles are ridiculously wide. Even with the ryft axles there's no way the shocks are going to mount on the trailing arms as it sits. I did some quick measurements and I need to move the upper mount points in about 20mm per side to match more closely to the bomber chassis.
I ordered some aluminum tube to make the new cross bars for the shock mounts (I'll use the included upper mounts). I'll have to cut one section of tube from the chassis for clearance and it should be good to go. I'm sure I'll have some issues to resolve with the sway bar as well, but I'll get there in turn.
Here's some pics of the chassis side by side with the Bomber chassis, and progress shots.
New skid with the original side mounted
Front shocks barely clear the chassis. I'll probably trim the spot that's close (next to the shock body) slightly just in case
Here's the shock issue. The fix should be easy, just waiting on material before I start cutting
