Hi everybody , I'm newbie
I have a question about BEC....
I ve seen the Harley's diagram that shows 2 ways to bind BEC and servo to RX
The first is the most simple and that's what I used, having a RX Futaba R304SB that run at 7.4v: BEC goes directly into bus port of RX
The other diagram shows the binding from servo to RX with yellow signal wire only (BEC gives the power directly to servo) even though the RX is 7,4 v in this case as well.
Is there any difference assuming that's 7.4v RX in both ways?
I have a doubt on that because my servo hitech ....seems doesn't pull as expected ( I might hold it pretty easy)
Thanks!
Castle Creation BEC 10 Amp +MMP
Thanks!
