Jeepfixer1
Awesome build to follow along with. Almost like a guide on how to pimp your tf2!
Moe, your sickest build to date bro! Can't wait to see it all done.
That's a huge help. A couple things I wouldn't have thought of. Thanks
Do you spot weld then braze or just braze? All I have right now is a brazing kit.
Awesome build to follow along with. Almost like a guide on how to pimp your tf2!![]()
Why don't the bed line up with the cab correctly?
Thanks man! The body misalignment though, not sure. Seen other people complain of it on here too. The passenger front corner of the bed was way low making the bed out of square. While I was bobbing the bed I heated it and tweeked it back for the most part, but lost a bit while finishing the bob. Thinking of getting a Tamyia bed to try, but I'll prolly wait a while.
I've seen issues with the bodies but in this case you can't say that in good conscience. When you ran the cab back, cut the tabs on the bed and mounted it, you eliminated any chance of it fitting normally. The bed normally mounts to 4 fixed points on the cab.
What others have complained about is that the cab and bed are tweaked once bolted together.
This sure looks like Durango.I'd like to maybe check out your tf2 if you are up for it.Hey all, got out a bit this morning for a run. Only had a little time between sun warming things up, and clouds rolling in to get em cold again. Realizing now the bummer of getting this rig done as summer disappears from the rear view. And found the low rear really killing performance. Less flex, and catching the trans skid on so much more. But none the less fun and can't wait to get out again. Anyway here's the promised trail pics..
Very nice yoder. I just cannot dig your jeep banner.![]()
