BIGW0RM
Hey all,
I pulled my TF2 off the shelf and busted it out. I ended up breaking my K44 front hub clean off. I actually did this with the stock yota axles too! My servo must be too much at 500oz.
Anyways, Im trying to get this up and running again. Frankly I am not happy with RC4WD axle quality. Both the stock and k44 RC4WD axles either broke or stripped out at the hubs.
I found these on ebay. My question... Is this same metal as the RC4WD stuff? Or is it worse?
https://www.ebay.com/itm/ARB-Editio...173233&hash=item1aa2d50b82:g:V58AAOSwy2NfWcSo
Ive seen a few comment about the ring and pinion being easy to strip. Is is the same metal and or ring and pinion RC4WD uses? If not, can I just use my RC4WD ring and pinion in these?
Or should i just buy an SCX10 II builders kit and slap my TF2 body on it? the goal is to keep the Hard body toyota body more than anything.
So do I buy a full replacement axle set for 100-200 bucks? Or do I buy kit I can slap this TF2 hard body on and be done with the TF2 chassis?
Thoughts? Suggestions?
Thanks!
BW.
Thanks!
BW.
